2D_with_kinematic_coupling
Greetings group,
I have an issue with 2 plates connected with kinematic coupling from the same reference node. When i apply explicit displacement to the ref. node, the displacement applies only to 1 plate.
Any suggestions? is something wrong with the setup, or just a bug?
The problem is 2D plane stress problem.
The model is available in the link below (too big to be attached here.)
Thanks in advance for the help
Check this thread: Coupling constraints with shells - Analysis issues - CalculiX (official versions are on www.calculix.de, the official GitHub repository is at https://github.com/Dhondtguido/CalculiX).
Coupling constraints in CalculiX may not work well with shells, and kinematic coupling needs a node-based surface to work with them:
Yes i confirm, connect node-based surfaces and ref. node with coupling constrain and problem solved!. Thank you so much :slight_smile:
Since node-based surfaces can also be used by solids, maybe all kinematic couplings should use node-based surfaces instead of element-based?
It definitely makes sense, but I still hope for some feedback from the CalculiX community. According to the manual, element-based surfaces should be used:
With SURFACE the nodes are selected to which the constraint applies (so-called coupling nodes). This surface must be face-based.
With this keyword kinematic constraints can be established between each node belonging to an element surface and a reference node.
So there might be some issues/limitations of this approach with node-based surfaces. I think I’ll just ask Guido directly.
The 3D analog of yesterday’s problem in the below link. It seems, the element-based surface works fine with kinematic coupling for 3D case.
Yes, there’s a problem with kinematic couplings only when using them with shells.
