Job failed with second order elements
Hey Everyone,
i’m facing a problem with solving a static analasys when the geometry was meshed with second order elements. I was using the basic meshing option of pre pro max.
When solving the job with linear elements, everything works fine.
Maybe i’m doing smth. wrong in meshing.
Thanks in advance
Eric
Hard to say without knowing the details. Are there any error messages ? Can you show the model setup ?
Shure,
so i have an centrifugal impeller.
To demonstrate the problem with second order elements, it is as simple as possible.
I have meshed with the basic meshing setup. Second order elements active and set the element size to a reasenable value. Only one refinement was done at the rim of the impeller to assure enough geometry resolution. There is a fixed BC on the Hub, as shown in the sceenshot. The impeller rotates with 300 rad/s around the z axis.
When i solve this model, the monitor is showing this message:
The numbers below are estimated upper bounds
number of:
nodes: 1479192
elements: 881096
one-dimensional elements: 0
two-dimensional elements: 0
integration points per element: 4
degrees of freedom per node: 3
layers per element: 1
distributed facial loads: 0
distributed volumetric loads: 1
concentrated loads: 0
single point constraints: 11748
multiple point constraints: 1
terms in all multiple point constraints: 1
tie constraints: 0
dependent nodes tied by cyclic constraints: 0
dependent nodes in pre-tension constraints: 0
sets: 4
terms in all sets: 3526342
materials: 1
constants per material and temperature: 2
temperature points per material: 3
plastic data points per material: 0
orientations: 0
amplitudes: 5
data points in all amplitudes: 5
print requests: 0
transformations: 0
property cards: 0
STEP 1
Static analysis was selected
Decascading the MPC’s
Determining the structure of the matrix:
Using up to 12 cpu(s) for setting up the structure of the matrix.
number of equations
4431702
number of nonzero lower triangular matrix elements
164843643
Using up to 12 cpu(s) for the stress calculation.
Using up to 12 cpu(s) for the symmetric stiffness/mass contributions.
Not reusing csc.
  • PaStiX : Parallel Sparse matriX package     +
Version: 6.0.1
Schedulers:
sequential: Enabled
thread static: Started
thread dynamic: Disabled
PaRSEC: Disabled
StarPU: Disabled
Number of MPI processes: 1
Number of threads per process: 12
Number of GPUs: 0
MPI communication support: Disabled
Distribution level: 2D( 128)
Blocking size (min/max): 1024 / 2048
Matrix type: General
Arithmetic: Float
Format: CSC
N: 4431702
nnz: 334118988
Job failed - no results exist.
Process elapsed time: 94.497 s
When i change the meshsetting to linear element order, the monitor is showing this message:
number of:
nodes: 225597
elements: 881096
integration points per element: 1
single point constraints: 3312
tie constraints: 0
sets: 4
terms in all sets: 3524936
materials: 1
orientations: 0
amplitudes: 5
print requests: 0
transformations: 0
property cards: 0
STEP 1
number of equations
675135
11920437
Not reusing csc.
Version: 6.0.1
Schedulers:
sequential: Enabled
PaRSEC: Disabled
StarPU: Disabled
Number of GPUs: 0
Arithmetic: Float
Format: CSC
N: 675135
nnz: 24516009
Ordering step :
Ordering method is: Scotch
Time to compute ordering: 0.6300
Symbolic factorization step:
Symbol factorization using: Fax Direct
Number of nonzeroes in L structure: 218993472
Fill-in of L: 8.932672
Time to compute symbol matrix: 0.1129
Reordering step:
Split level: 0
Stoping criteria: -1
Time for reordering: 0.2282
Analyse step:
Number of non-zeroes in blocked L: 437986944
Fill-in: 17.865344
Number of operations in full-rank LU : 498.27 GFlops
Prediction:
Model: AMD 6180 MKL
Time to factorize: 18.8646
Time for analyze: 0.0414
Factorization step:
Factorization used: LU
Time to initialize internal csc: 2.7794
Time to initialize coeftab: 0.1206
Time to factorize: 11.1591 (44.65 GFlop/s)
Number of operations: 498.27 GFlops
Number of static pivots: 0
Time to solve: 0.0927
- iteration 1 :
total iteration time 0.0986
error 1.8785e-07
- iteration 2 :
total iteration time 0.101
error 3.0834e-11
- iteration 3 :
total iteration time 0.108
error 1.0337e-14
Time for refinement: 0.3722
- iteration 1 :
total iteration time 0.102
error 7.5287e-17
Time for refinement: 0.1628
CSC Conversion Time: 0.057964
Init Time: 1.105466
Factorize Time: 14.060342
Solve Time: 0.655722
Clean up Time: 0.000000
Sum: 15.879494
Total PaStiX Time: 15.879494
CCX without PaStiX Time: 11.506344
Share of PaStiX Time: 0.579843
Total Time: 27.385838
Reusability: 0 : 1
Job finished
Total CalculiX Time: 31.601422
Process elapsed time: 31.727 s
Larger meshes often cause problems in CalculiX and then it’s best to try with a different solver. Here you could use Pardiso instead of PaStiX. It can be selected in the step settings.
