By read wrong I mean undervalue the importance of REF node position. (bad english from my side)
Rotations of the rigid body are done arround him.
Can you share the file with your model so that we can try to make some improvements ?
sorry i i missed at this. It seems not possible to remove some dof’s at node in continuous mesh, separation and connecting by MPC is required.,
I have been able to connect all three shell components but with many custom keywords. (The system is unstable and stability is far from its actual position. I have help the system to converge with some addition constrain but, anyway, that’s another matter).
In Prepomax it doesn’t seem to work even with some additional BC , and I think i see the reason.
Does Prepomax always create a new node number for the REF node?. I mean, I have selected as reference node an existing node which is part of a component. I know that’s possible. For some reason when I do that, Prepomax creates a new node at the selected position instead of using the selected node.That makes both parts disconnect.
Could that option have been added to Prepomax?
In PrePoMax, a new node is created as a reference node on the location of the selected point.
