Normally, created history outputs are graphically highlighted in the result tab when selected/hovered with the cursor. However, as soon as pre-tension is involved, this no longer works.
I don’t know if this is a known limitation or a bug, but I’m hoping it’s a bug that can be fixed ![]()
Thanks
highlighting without pre-tension:
behavior with pre-tension activated:
