how to create a thermal simulation of heat transfer between 2 components that are in contact
Do you mean how to connect them so that heat can flow between them ? You can use either tie constraint for perfect connection or contact with gap conductance if there’s some thermal resistance in the interface.
Heat flow.pmx (152.8 KB)
yes, do you have a video tutorial?
I used tie constraints in heat transfer analysis here: https://www.youtube.com/watch?v=sfY5BEHUsmk
If the parts are touching, tie constraints should work. If there’s a small gap, you can change the tolerance and enable adjustment. The master surface should be the one with a coarser mesh.
Add a new Analysis object (e.g. Analysis-2) and try submitting it again.
