Please can any one help. This model all symmetric but why this region shows different temp value.
Waht I did: Merge Coincident Nodes
tie contact. I try to solve by AI but I am really confused.
Please share the .pmx file here or via a hosting website. You may need to use File → Close All Results before saving the file, though (to reduce its size).
piramit2.pmx (3.8 MB)
this is my file.
It seems that you are unnecessarily using shells here while it should be a solid (not hollow) geometry:
So you should try importing one solid part or stitching all these faces into such a solid. To use shells, you would need only one surface (midsurface or top/bottom surface) per thin part.
Btw. when you have multiple parts, they are treated as disconnected. Creating a compound part out of them will ensure a continuous mesh and heat transfer through the whole component.
I mean that you should try with a geometry like this:
piramit2 solid.pmx (62.5 KB)
Although it’s still very thin-walled and may actually require proper shell modeling or a different approach (e.g. some simplification/homogenization or local analysis).
And I think that were some flaws in the final solid, but you should get the whole idea now.
Thanks in advance. But when I wanted to make it solid, the software didn’t accept this feature. I don’t understand why.
FEAnalyst <notifications@prepomax.discoursemail.com>, 23 Eyl 2026 Çar, 17:35 tarihinde şunu yazdı:
WARNING! NOT ALL FACES HAVE BEEN MESHED
09/23/26 18:57:36 SURFACE MESHING ERROR OCCURRED IN 107 FACES:
Mesh finished with failure.
mehmed çelebi <mehmed.celebi@gmail.com>, 23 Eyl 2026 Çar, 18:53 tarihinde şunu yazdı:
How did you prepare the geometry ? In what CAD software ?
I convert to shell part. And then still some flaws:
mehmed çelebi <mehmed.celebi@gmail.com>, 23 Eyl 2026 Çar, 18:58 tarihinde şunu yazdı:
To use shells, you should have only one surface (typically midsurface) for each rib or plate. And merge all surfaces. Here, they are probably still disconnected in some places.
This geometry is too complex; you should start with a simplified version. You can also analyze a quarter of this model (utilize symmetry), but the geometry still needs careful preparation.
Actually, if you take a closer look at this geometry, ribs on one side are not fully connected:
On the other side:
This is the problematic side:
This explains the asymmetry.
Also, aren’t the units off ?
Make sure that you export and import geometry in the proper unit system.
How can I analyze a quarter of this model.
Thanks.
FEAnalyst <notifications@prepomax.discoursemail.com>, 23 Eyl 2026 Çar, 20:06 tarihinde şunu yazdı:
You would have to cut it in CAD software in such a way that you keep only a quarter of the whole part:
In thermal analyses, you don’t need any specific boundary conditions for the symmetry edges/surfaces because the default BC allows for that.
How can i define a liquid in the software to make heat transfer? Especially between two solids.
MC
FEAnalyst <notifications@prepomax.discoursemail.com>, 24 Eyl 2026 Per, 15:31 tarihinde şunu yazdı:
There are 3 ways:
Whichever approach you choose, make sure that your heat exchanger itself is properly modeled and can be correctly simulated on its own.
