Hello Matej,
I would like to request and suggest a way to implement multiple load combinations that from my point of view would not require too much changes known the actual set of tools.
We now have the Parameters tool.
If the number of columns could be extended in such a way that each column could represent a new Load case , adding the parameter into the Load definition would suffice to have available the whole collection of load combinations.
The Load combination column of interest could be selected/loaded into the final parameters in the analysis window.
In case assigning a zero value to a parameter could generate issues, I would also add the option “disable” which would directly disable the load on the tree where that parameter has been introduced.
It would also be interesting that such table of Parameter could be saved/exported/imported as it would represent the different safety coefficient for an specific code and would not change form model to model.
See pictures as example.
Regards
