Exporting data correctly in excel
Good morning,
I’m trying to export the displacements of a surface to excel, in order to make some calculation.
I created a node set of the surface, and the reuslts are displayed in a ‘’.dat’’ file. But, if I copy and paste these values in excel, they are all on the same cell.
Then, I tried, by using results → history outputs → create; so, I selected ‘‘ALL’’ (because I need the total value, not the components) and then selected the surface. But I get only 100 nodes, I need all the nodes in the surface selected. If I use that second method, the values are stored correctly in excel, but I need all the node values.
Is there a way to get what I need?
Thank you.
In Excel you can set some data import options including custom separators. If you do it properly, the outputs should be placed in individual cells.
I tried, it worked, but all the -1,8E-02 are transformed in -1,8E+02
That’s strange. Maybe try finding and replacing all occurances of E-02 with e.g. 10^-2.
But I have around thousands of rows, is there a fast way for doing it?
In both Excel and text editors (including Notepad) there is a Search and Replace tool that can do this for all entries.
I tried but doesn’t work with the ‘‘E+’’ of numbers
¿Don’t you mean -1.8E-02 are transformed in -1,8E+02?. Notice the point and coma difference.
*.Dat files use “.” and your Excel might be using Commas as decimal separator.
In Excel you need to use “split into columns”.
You’re right, I didn’t notice it, now it works because I set ‘’.‘’ into ‘’,‘’ in the conversion window.
Thank you a lot.
