I am getting some errors making compound surface parts. It seems fairly random from what I can tell.
The error you get is connected to the file name (as it seems). Are you using a very long absolute path to the PrePoMax folder? Try moving the PrePoMax folder to a shorter path, like c:\PrePoMax
But it could also be a consequence of the compounding process, which takes place using the Netgen library that uses OpenCascade. There, I have limited possibilities of improving it.
Can you preapre an example?
