I have calculated same model before but with orce from mass points applied at other points (instead of being applied to the surface in the acting model, it is applied to the whole part)
Assuming that you are on Windows platform, open your Task Manager (CTRL + ALT + DELETE) and go to Performance Tab to see if you are running out of memory while the analysis is running.
Check also the reading & writing usage of your HDD/SSD drive while analysis is running. Reason being that if the analysis runs out of memory it then resorts to using your HDD/SSD to store and read data for the calcs.
I’ve checked that analisys at 2.3.0 version and now it go through calculations but killed due zero coeficcient - I think i have to check model
And also checked ram usage at 2.3.0 maximum usage by software was 18gb (25/32 gb overall)
