The error occurs when trying to use this feature:
I have tried it in several scenarios, and it works for me.
Could you share more information about it?
While trying, I also found some bugs and resolved them.
This is strange. I do nothing special, i tested again with the newest dev. version from today:
all i do is:
create a new file
import simple geometry (a quadratic face)
mesh with standard Meshing parameters
go to model > tools > remesh Elements > the error still occures:
But if you could not easy reproduce this error and no one else can confirm this, it must be an individual problem on my side. However with older versions (1.3.0) it’s still working for me:
Do you have the file mmgs.exe in the Netgen folder.
I think I found the problem and I have fixed it.
Can you check if the refinement bug is fixed?
Yes it’s fixed, this topic can be closed.
