06/07/26 18:44:04 Elapsed time [s]: 14.8556259
06/07/26 18:44:04
06/07/26 18:44:04 Converting mesh to second order…
06/07/26 18:44:09 Nodes: 234280
06/07/26 18:44:09 Elements: 149149
06/07/26 18:44:36 Add step: Step-1
06/07/26 18:44:36 Add default analysis:
06/07/26 18:46:40 Add surface: Surface-1
06/07/26 18:47:03 Add surface: Surface-2
06/07/26 18:47:13 Add surface: Surface-3
06/07/26 18:47:19 Add surface: Surface-4
06/07/26 18:47:25 Add surface: Surface-5
06/07/26 18:47:34 Add surface: Surface-6
06/07/26 18:47:43 Add surface: Surface-7
06/07/26 18:47:49 Add surface: Surface-8
06/07/26 18:47:59 Add surface: Surface-9
06/07/26 18:48:07 Add surface: Surface-10
06/07/26 18:48:14 Add surface: Surface-11
06/07/26 18:48:20 Add surface: Surface-12
06/07/26 18:49:13 Add surface: Surface-13
06/07/26 18:49:22 Add surface: Surface-14
06/07/26 18:49:49 Add surface: Surface-15
06/07/26 18:50:14 Edit surface: Surface-13, Surface-13
06/07/26 18:50:31 Add surface: Surface-16
06/07/26 18:50:53 Add surface: Surface-17
06/07/26 18:51:02 Add surface: Surface-18
06/07/26 18:51:12 Add surface: Surface-19
06/07/26 18:51:20 Add surface: Surface-20
06/07/26 18:51:32 Add surface: Surface-21
06/07/26 18:51:40 Add surface: Surface-22
06/07/26 18:52:16 Add surface: Surface-23
06/07/26 18:52:26 Add surface: Surface-24
06/07/26 18:52:49 Add BC: Step-1: Fixed-1
06/07/26 18:53:02 Add BC: Step-1: Fixed-2
06/07/26 18:53:20 Add BC: Step-1: Fixed-3
06/07/26 18:53:33 Add BC: Step-1: Fixed-4
06/07/26 18:53:45 Add BC: Step-1: Fixed-5
06/07/26 18:53:59 Add BC: Step-1: Fixed-6
06/07/26 18:54:11 Add BC: Step-1: Fixed-7
06/07/26 18:54:28 Add BC: Step-1: Fixed-8
06/07/26 18:54:39 Add BC: Step-1: Fixed-9
06/07/26 19:08:50 Add BC: Step-1: Fixed-10
06/07/26 19:09:00 Add BC: Step-1: Fixed-11
06/07/26 19:09:11 Add BC: Step-1: Fixed-12
06/07/26 19:12:21 Add load: Step-1: Pressure-1
06/07/26 19:12:34 Add load: Step-1: Pressure-2
06/07/26 19:12:51 Add load: Step-1: Pressure-3
06/07/26 19:13:06 Add load: Step-1: Pressure-4
06/07/26 19:13:20 Add load: Step-1: Pressure-5
06/07/26 19:13:34 Add load: Step-1: Pressure-6
06/07/26 19:13:45 Add load: Step-1: Pressure-7
06/07/26 19:13:59 Add load: Step-1: Pressure-8
06/07/26 19:14:13 Add load: Step-1: Pressure-9
06/07/26 19:14:25 Add load: Step-1: Pressure-10
06/07/26 19:14:40 Add load: Step-1: Pressure-11
06/07/26 19:14:54 Add load: Step-1: Pressure-12
06/07/26 19:15:03 Run analysis: Analysis-1
06/07/26 19:15:03 Add element set: Missing_section-1
06/07/26 19:15:12 Model exported to file: C:\Users\PC\Desktop\programlar\PrePoMax v2.5.0\PrePoMax v2.5.0\Temp\Analysis-1.inp
06/07/26 19:15:20 Run elapsed time: 17.739 s
06/07/26 19:15:25 Open results: Analysis-1
06/07/26 19:16:16 Model saved to file: C:\Users\PC\Desktop\work\ahmetyanık\rotor_w_magnet.pmx
06/07/26 19:17:32 Edit element set: Missing_section-1, Missing_section-1
06/07/26 19:17:40 Run analysis: Analysis-1
06/07/26 19:17:40 Add element set: Missing_section-2
06/07/26 19:17:58 Remove element sets: [Missing_section-2]
