Difference between TOSTRAIN, MESTRAIN and PE
Good evening, I do not fully understand the difference between TOSTRAIN, MESTRAIN and PE in results: can you please explain me the difference or point me out some references where I can find informations?
Thank you!
  • TOSTRAIN - total strain (mechanical including elastic and plastic + thermal)
  • MESTRAIN - mechanical strain (elastic and plastic)
  • PE - plastic strain
Thank you for the exhaustive answer: in the meantime I ran a coupled temperature-displacement simulation, using temperature dependent material properties. Although TOSTRAIN reach values of 0.67 PE still is 0 for each step and each calculus iteration (NLGEOM is ON).
The material I am analysing is a PBT (Polybutylene Terephthalate), for which I provided stress-strain curves for different temperatures in the plastic regime, as well as different elastic moduli at differen temperatures.
Am I missing something?
Do the stresses exceed the yield strength of the material ? Did you define plasticity starting from yield strength and zero plastic strain and then adding more true stress vs true plastic strain points ?
Yes, stresses exceed yield strenght: I defined material curves as you described, starting from yield and zero plastic strain, up to ultimate stress. first point in material curve is 33MPa, I reach 142 MPa.
What if you remove all temperature dependencies, thermal BCs / loads and run a purely mechanical analysis ?
Can you share the file ?
Unfortunatelly I cannot share the model due to intellectual property restrictions. I did further analyses:
  1. coupled thermo-mec. analysis, same material (temp. dependent, without deleting material properties at different temperatures), at one specific temperature → PE=0
  2. coupled thermo-mec. analysis, same material (temp. dependent, deleting material properties at different temperatures other than the one used in analysis), at one specific temperature → PE=0
  3. coupled thermo-mec. analysis, mec. prop. independent from temperature, at one specific temperature (it should be the same as a pure mechanical analysis) → PE=0
  4. static analysis, mec. prop. independent from temperature, → PE up to 0.49
Here some screenshots of analysis 2,3 and 4:
Analysis 2 (auto-def is ON)
Analysis 3 (auto-def is ON)
Analysis 4 (auto-def is ON)
Between analysis I didn’t change anything, I created analysis cases inside the same model.
So just changing the step type from coupled temperature-displacement to static results in PE ≠ 0 ?
You could compare the input files after exporting to make sure that’s the only difference.
I made a single element test and I get non-zero PE with this kind of step and temperature dependence. Maybe try playing with it and adding features from your model to see if it still works:
PE temp test.pmx (36.5 KB)
I found out what I was doing wrong! Since I was interested only in thermal expansion of component, I didn’t define specific heat and thermal conductivity, turns out it is essential to have PE in results!
Good to know. CalculiX often just fails without errors or doesn’t provide some results without warnings when something is missing in the setup.
