I used rigid body constraints where I have holes that bolts would be (did the 3 node selection to create a node at the center of the hole) and constrained those for U1/2/3 and wanted to try and pull the forces at these nodes I made but when I pull up results the rigids & node are gone so there’s nothing to query on. Is there a way to do this or should the model maybe be defeatured more so there’s no holes and I just constrain a node there from the actual model?
Thanks
Before running an analysis, create a history output request for those reference points and choose RF as an output variable. Then the desired results will be available from the results tree when the simulation is completed.
maybe node reaction (totals only) in history outputs needed to be set to default as requested, similar with stress and displacement in field outputs.
