Hey all,
Just fought through an issue in regards to a modal analysis with suspicious results, compared to hand calcs and other solvers and finally got the expected result… Which leads me to asking for this feature.
Basically, modal analysis is expecting density to be in units of mass. When your default unit system is in, lb, s, etc., density is in units of force (lbf/in^3). When performing a modal analysis, you have to change density units to slinches (slug-inches, manually). Most modern solvers will do this automatically on the back-end and we don’t think about it. NASTRAN makes you keep track of this, and requires the input “WTMASS” on the analysis setup. “WTMASS” is simply scaling your density units from force (lb), to mass (slinch), for this conversion, the value is 1/386.1.
Is it possible to implement a similar scaling option somewhere? Honestly just having another entry box in step setup would be perfectly fine.
Although it’s fine to track this manually and just enter density as units of slinches, it can get tedious. If the goal is that PrePoMax is unit aware, then something like this should be implemented eventually (either back-end and automatic, or entry box).
EDIT: Should also add that I feel like this is the purpose of the “gravitational constant” input box, but please correct me if I’m wrong about that. However, changing the gravitational constant has no effect on the results.
