Delete rows in material definition table
You can delete the row if you select the entire row by clicking on the first empty column in front of the row to be deleted and then press the Delete key.
The new row of zeroes is created when the user clicks on one of the empty cells in the last row. If the user doesn’t enter any value and just selects one of the above rows, the last row is set to empty again.
