Here is a table describing the plastic strain curve. I wanted to delete some of the entries to help with convergence and realized that one can’t delete. You can “cut”, but that sets the row to 0,0.
Also, sometimes, while adding a last row of data, an extra row of 0,0 will be added automatically. I notice that it has a periodicity to it…not here, not here, then you add your final value and SURPRICE! new 0,0 row is created.
You can delete the row if you select the entire row by clicking on the first empty column in front of the row to be deleted and then press the Delete key.
The new row of zeroes is created when the user clicks on one of the empty cells in the last row. If the user doesn’t enter any value and just selects one of the above rows, the last row is set to empty again.
