Is there a way of creating (separate) default colours for Master/Slave surfaces to make easier the identification of them at first glance of e.g. a ‘Tie conrtaint’?
At the moment, you can’t change it by default (only the color used by both of them and the highlight colors).
@Matej I’ve also noticed what seems to be a bug - in 2.4.0, the tie surface colors change only when the constraint is created. Afterwards, when you edit the constraint and change the colors, they don’t update in the model view.
Thank you for the quick answer.
Yes, I have noticed it also. It is a bug.
Also after the item is created, the color change does not work correctly.
If you create constraints manually and need similar settings, the fastest way is to duplicate the constraint.
