Continuing the discussion from 2D Axisymmetric *ERROR in e_c3d: nonpositive jacobian:
In SolidWorks to create surfaces for an axisymmetric analysis of an assembly do the following:
Model the assembly in Solidworks.
Using an extruded cut, expose the surfaces you want in the axisymmetric analysis.
Save the assembly as a SolidWorks part file (no need to do feature recognition).
Open the part file and select the surfaces you want to use.
Save the file as a STEP file.
The following dialog box will appear.
Choose “Selected face(s).”
A STEP file with the surfaces will be created.
Import the STEP file into PrePoMax
