I’m trying to simulate a bending process in a sheet metal part using PrepoMax. The simulation works fine at the start and the end of the process, but I’m noticing collisions in the middle of the bending.
But first of all, you should define contact pairs only on the surfaces that will touch during the simulation. So only the bottom of the punch, top and bottom of the plate and top of the die.
Make sure that master is on the stiffer part and has coarser mesh. Btw. you may have to refine the mesh, especially around the corners. It’s often necessary to specify non-default contact stiffness too.
Yeah, apart from the aforementioned suggestions regarding meshing, it looks good. There’s no interference in contact when the deformation scale factor is set to 1 (true scale deformation).
