[PL] Sorry for translation errors.
When creating a volumetric structure, you can select C3D10 and C3D10T. Unfortunately, in the CALCULIX 2.9 documentation, I have not found any information about the differences between these elements.
Has anyone used C3D10T elements and for what?
6.2.8 Modified ten-node tetrahedral element (C3D10T) Pag 97 manual ccx v.2.20.
http://www.dhondt.de/ccx_2.20.pdf
Thank you for your help. It follows from document 2.20 that the C3D10T element should be used for thermal analysis.
More precisely, it’s used for thermo-mechanical analyses.
