I am trying to run a simple 2D axisymmetric model. I am running into issues at location of axis-symmetric line (x=0), see picture below.
The end goal of this simulation was to simulate contact conditions between two soft hyper elastic materials (approx 1 and 10 MPa), but currently I am already running into issues with linear materials, NLGEOM=OFF.
Why is the 1st element always penetrating the harder surface, regardless of how I set the mesh? I assume it has something to do with CAX8R being expanded to a wedge element?
You could try revolving this geometry into an equivalent narrow wedge, applying proper BCs and running with 3D elements to confirm this. Unfortunately, CalculiX’s 2D elements aren’t really robust.
So it is indeed the wedge element that is causing issue. Physically, would it be still ok to minimally display the model for a small X and achieve OK results?
Perhaps even smaller translation would suffice. You can compare the results with the solid elements approach (e.g. from my file attached above) to make sure there’s no discrepancy.
