Is that a failed attempt to share the file directly here ?
Anyway, it seems that you applied this concentrated force to the edge. Here’s an explanation why it shouldn’t be used on surfaces in most cases: Don't apply concentrated force load to surfaces but it applies to edges as well if you don’t want the specified magnitude to be applied to each node (so the total load is specified magnitude*number of nodes).
