Job Failed - no results exist
I’m analyzing a part with complicated geometry in a twisting setup.
I’ve fixed one part and am applying a moment to a reference point that is part of a rigid-body constraint.
The model seems to mesh ok, but when I run the analysis it simply says “Job Failed - No results exist” after 79s. The output dialog doesn’t seem to hint at why. What should I be checking?
I’m using PrePoMax v2.0.0
Here’s a link to the file. There’s a txt file with the output
More about our goals (less relevant to the question):
We’d like to know the torque at which the part begins to break - for this analysis
We’ll create a very similar analysis with updated geometry and compare the forces between the two. In the end our goal is to say “this is 1.4x as strong when loaded similarly” (or some other multiplier)
There are no links or files attached.
whooops
It sometimes happens with bigger models when default solvers are used. Try switching the solver to Pardiso (works for me) or using coarser mesh. But you should also constrain it in the Z direction.
