Hi, the new anotations looks wondefull, can be added in the future the material name and basic properties to the Part anotation? Also, would be incredible amazing a function to create a table with this info (for all parts of the model), would help a lot when we document the model.
Hmm, adding new data to existing annotations or adding completely new annotations now is pretty easy. I find the part annotation already quite full, so I am thinking of a new annotation for material only. But then the connection between the part name, mesh properties and the material will be lost. So not an optimal solution.
A table is something else. Unfortunately, it will require more work ![]()
The first next feature I will implement will be the hydrostatic load.
There is a problem I did not think of before. The section can be created based on an element set. That means that a part can have multiple materials. So adding one annotation for each part about the material name and properties is not a general solution.
