How is it possilble that there is 10 times difference between loads, but only 1,28 times difference between buckling factors?
You will likely have to correct the load definition - check this: Don't apply concentrated force load to surfaces
Also, it might be better to apply a unit load so that the buckling factor is the actual buckling load, not just multiplier.
Now this works. Thank you.
