CGJ
June 13, 2024, 9:37am
21
I want to use umat in prepomax. Here is my inp file,
but I encountered the following warning while running. Why is this
Is that elset properly defined ? Does it work with any built-in material ?
CGJ
June 13, 2024, 10:31am
23
This is my file
1.pmx (1.1 MB)
Try with *SOLID SECTION, ELSET=Solid_part-1 or define that elset All in GUI.
CGJ
June 13, 2024, 10:45am
25
I changed * SOLID Section, ELSET=Solid_part-1, but a new error occurred
Then you should also add the *ORIENTATION keyword via the keyword editor (syntax described in the ccx manual). After all, this is Barlat’s anisotropic plasticity model, right ?
CGJ
June 13, 2024, 12:33pm
27
It’s a bit strange to see this error when opening result after the calculation is completed
Try in PrePoMax 2.1.0, support for material names with @ was added in 2.0.6 dev version: A developer/preview PrePoMax version v2.0.6 has been released
CGJ
June 13, 2024, 12:49pm
29
The new version is indeed useful. Thank you.
CGJ
June 23, 2024, 12:23pm
32
I was using Umat material simulation at PrepoMAX and had some confusing issues. My steps are as follows
Compile the umat code sdv.f file to libsdv.dll
Call the libsdv.dll in keywords. *Material, Name=@ABAQUS_sdv
*USER MATERIAL, CONSTANTS=2
200000,0.3
**Young, Pisson
*DEPVAR
2
*Solid section, Elset=Internal_Selection-1_Solid_Section-1, Material=@ABAQUS_sdv
An error is reported in the running result.
But when I changed sdv.f to umat.f, it worked successfully by following the steps above. So is it an issue with sdv.f, or is there something wrong with my setup.
Attach my whole files.
WeTransfer - Send Large Files & Share Photos Online - Up to 2GB Free
