Material Change between two steps
Would it be possible to redefine the material parameters in a second Step?
I mean, to perform an analysis up to a certain load with one material and a different material “for the same mode” on the second step but respecting the previous Stress State. Kind of a phase change.
I recall reading somewhere a similar question but I’m unable to find the post.
Thanks
In Abaqus, we sometimes use artificial temperature dependence of material properties if temperatures are not important. It was discusses on the CalculiX forum as well: Specifying dependencies of material properties to a defined field - CalculiX (official versions are on www.calculix.de, the official GitHub repository is at https://github.com/Dhondtguido/CalculiX).
I knew I sow that somewere.
Thanks. I will try the temperature aproach.
