The problem of passing through a surface without visualizing it in dynamic analysis
Hello, when performing dynamic analysis, even though I added hard and friction to the surface interaction section, defined master and slave surfaces, and tightened the mesh structure at the collision site, the impact is still passing through the surface. I need to solve this problem for ground impact analysis. Can you help me? Thank you.
merhaba, dinamik analiz yaparken surface interaction kısmını hard ve friction ekleyip master ve slave yüzeyleri tanımlayıp çarpışma olacak yerdeki ağ yapsını sıklaştırmama rağmen yüzeyin içinden geçmektedir.
Zemine çarpma analzi için bu sorunu çözmem gerekiyor yardımcı olur musunuz,teşekkür ederim
Translation added. Please use English or at least include translations when writing on the forum.
Your deformation scale factor is set to Automatic and it’s scaled over 3 times. Try with the True scale (scale factor 1) setting.
