Hello everybody. What is the best strategy to simulate the temperature of an electric wire with the following characteristics?
- wire material: copper
- wire diameter: 3 milimeters;
- wire length: 2 meters;
- current on the wire: 5 Ampere;
- ambient temperature: 27 degrees.
Thank you all
Hello
Such simulations are usually done using Joule heating coupled analyses (heat transfer + electric currents). In PrePoMax it’s not available but you could use these formulas to calculate the necessary inputs for pure heat transfer analysis (or even get the analytical result for a simple case):
ρ = 1 / σ
R = ρ * (L / S)
Q = P * t = R * (I^2) * t
ΔT = Q / (c * m)
where: ρ - electrical resistivity of the material, σ - electrical conductivity of the material, R - resistance, L - length of the conductor, S - cross-sectional area of the conductor, Q - heat, P - power, t - time, I - current, ΔT - temperature increase, c - specific heat, m - mass of the conductor
Thank you very much.
I will try and i’ll send here the images.
Cheers
Giovanni
