I’m a stress/structures engineer and I regularly use ansys and msc tools for mechanical systems and interactions of those systems with housings and structures. We use a lot of contact and interference fits in our models!
Just recently we’ve been base lining contact management and performance in the packages available to us, using the same test - a simple shaft in a socket with interference fit. I decided I would try to solve this using prepomax/calculix over the weekend. The software solution is compared against a classical analytical approach away from stress concentrations/risers.
The setup and running was fine, once I understood the steps and generally the solve time was pretty good using 4 cores. The only stumbling block is that gmsh wouldn’t mesh the socket if I split the upper and lower surfaces using the vertexes of the axial edges. I wanted to do this to create a history plot along an edge.
After a little searching I see that you can add a keyword to transform the orthogonal axis system to a cylindrical one, and it would be great if that could be defined in the GUI at some point. I need to add that keyword and re-run.
We are assessing the contact pressures and the radial stress in the socket, away from the socket edges. In ansys it’s straightforward to create a construction line and plot stresses along that line. How would the forum suggest doing similar with prepomax?
I tried to import a line element or axis in the step file (made using freecad) but that doesn’t seem to be permitted. I tried splitting a surface to get a radial edge, but that creates problems with meshing.
I can get a history plot along an edge (say the socket axial surface edge) so maybe I could split up the socket in to separate bodies in freecad, import them and make compound meshes from the individual body cells?
And maybe I haven’t found the option yet, but it would also be very useful to set fringe plot limits (for example in the attached image, show values between say 50-100MPa
All help always appreciated, and maybe I can contribute back in to the group.
(btw, my thanks go to the developers, I really like using this software - it’s simple and straightforward, mostly intuitive).
The contact pressure results are in line with both analytical and industry standard software results…
