Hi all
I have setup a Dell R730 server to run calculix jobs (version 2.22), it has two sperate cpus with 16 physical cores in each one. I am running some moderately complicated contact models but the server isn’t working hard at all (temps are near ambient etc) my drives are a bit slow but I checked that io and that isn’t the issue. the solver is only using 5gb (out of 128) of ram so that isn’t a bottleneck
I have run export OMP_NUM_THREADS=32 and the output says that it is running 32 threads
thanks
Luke
