Request for feedback-
For the attached metal pipe. I want to apply momentum in the center ( horizontal axis) by applying rigid body constraints on both ends
hollow motor shaft for pinion gear_sprocket v1.0.zip (12.8 KB)
How to do it ?.
Like this:
Pipe moment.pmx (1.7 MB)
Well This Iam aware. I want to place rigid body constraint on both the pipe end ( i.e. lock them)and apply torque in the middle of pipe in horizontal axis. I want to twist the pipe in the center i.e. at 80 mm .
middle of the pipe in vertical axis.
Then you will have to split the pipe in FreeCAD first. The ways of doing that are explained here: FEM Geometry Preparation and Meshing - FreeCAD Documentation
Pipe moment 2.pmx (1.8 MB)
