Hello everyone,
I am trying to run a simulation in PrePoMax with an orthotropic material (defined with Elastic, Type=Engineering Constants). My model is a solid mesh (C3D10 elements).
The problem is:
When I assign the material to my part, I don’t see any option to assign an Orientation in the Solid Section dialog.
In the exported
.inpfile, I only get:
*Solid Section, Elset=Solid_part-1, Material=Material-1
but I would expect something like:
*Solid Section, Elset=Solid_part-1, Material=Material-1, Orientation=CS_fibres_xWithout this orientation, CalculiX stops immediately (0 kB output).
Could you please explain:
How to correctly create and assign an Orientation to a solid part in PrePoMax?
Is this feature available in the GUI, or do I have to manually edit the .inp file?
Thank you very much for your help!
