Position tolerance not updating properly in v1.4.0
Hello, I’ve observed that the position tolerance is not being updated according to user input. By default, it remains set at 0mm. I attempted to verify this by checking the .inp file after making the updates, but it still reflected the value of 0mm.
I can confirm this. I set some value and confirm but when I go back, it’s set to 0 and 0 is also written to the input deck.
It is definitely a bug. I was playing around with the Tie constraint testing introduction of parameters. And obviously, I slipped some unwanted code in the released version.
I have fixed it and updated the release version.
