Performance Issue When Importing Large .inp File with STEP Command
Dear PrePoMax team,
I’m experiencing a performance issue when importing a large .inp file (around 100,000 elements). PrePoMax reads the file correctly, but the import takes a very long time only when the *STEP section is included. If I remove the *STEP part, the file loads quickly.
Here is a link to the .inp file for reference:
Thank you for the great software and support!
The problem is the number of *Equation keywords. They are converted to individual user keywords, which must be correctly indexed into the model-generated keywords, and this causes a big problem.
I will have to add grouping of similar keywords to the inp reader so that all *Equation keywords would be recognized as one.
If you have a script to prepare the *Equation keywords, you can try to define all the keywords under one *Equation keyword as:
*EQUATION
3
120945,2,1, 40143,2,-1, 121206,2,-1
3
120945,3,1, 40143,3,-1, 121206,3,-1
instead of:
*EQUATION
3
*EQUATION
3
Calculix can read such an entry, but I did not check the results to see if it really works.
Thanks Matej for you fast answer, I didnt know that, I’ll try it and let you know.
Unfortunately, that didn’t work. I remember trying to use a single *EQUATION keyword, but CalculiX didn’t read it properly, which is why I had to apply the keyword to each node separately.
As for PrePoMax, the issue persists. Here is a link to the modified .inp file with a single *EQUATION keyword.
Ok, I fixed some additional bottlenecks. The fix will be available in the next version. It will definitely work for a single *Equation keyword with multiple equations. I will try to add default keyword grouping, but I am not sure it will make it in the next version.
Ok, so i fixed some things in my script and it indeed worked in ccx with just one *equation command as you suggested. As with prepomax it’s the same. It’s not an issue since i can just run calculix outside and use prepomax for postprocessing only. Thanks!
I added some additional fixes so that now it will work much faster for a single or multiple keywords.
Thanks a lot!
I there a way to download a nightly build exe of prepromax? I am currently using 2.3.7 dev and I couldnt fine a release version on gitlab.
Try compiling with this script: CMD-script for automatic PrePoMax compilation
No, but I will probably create a new developer release in a day or two.
The new version works perfectly :+1:
I am closing this topic.
