Good day. Tell me, is there a test example for Optimax?
From what I know, there’s only the manual. Since the website is currently down, here are the files:
Optimax-USERS-MANUAL-v0.6.4.pdf.zip (772.7 KB)
OptiMax v0.7.0.zip (1.5 MB)
But I have a plan for Optimax tutorial and I will try to do it as one of the next videos (may take a while though).
Since PrePoMax now supports parameters from the command line, I think a tutorial in this way would be the most beneficial. I was also considering preparing it.
To be honest, I was waiting for potential support for parametric studies in GUI but I could show both ways - Optimax and PrePoMax with command line. It will take some time to prepare it so I guess that the beginning of the next year is most likely time for it.
Great, I’ll be waiting!
Is it finally done? I have checked your youtube channel and haven’t found anything… ![]()
Not yet. But there is a new article about it in Polish written by a colleague: Kalibracja nieliniowych modeli materiałowych z wykorzystaniem programów open source | Projektowanie i Konstrukcje Inżynierskie
I have done in the past some work to find Neo Hooke parameters for rubber material definition, and for what I remember, the tutorial included in the documentation has some issues in the data mining definition. I´m redoing the basic example (and probably look in my old emails with Matej) to document what I have to change it to run.
The Polish article that I referenced is also based on the documentation example. For me, there were some issues in the related ready-made Optimax file that I got, but it might be configuration-specific.
I have exactly the same error when I try to run the second part of the tutorial (fitting the results to the curve), and running in a workstation with no admin rights. I will test on my own pc later.
One thing that confuse me is that one first need to run the model in order to have the 3.1.1.7 Output array step to have an initial .dat file and get the results showed in the form. And even with that making the data mining filter working also need several tries.
EDITED, Is not the same error message, mine is about the curve comparation.
Yeah, in my case the error appeared after opening someone else’s file, changing all paths to the ones adjusted for my PC and running the workflow. I haven’t tried with a model built from scratch yet.
I have the same error as you at my own pc, setting the number of cpus for the solver to 1 fixed it. Looks like even running as admin it can’t set up environment variables.
