In the new version (1.2.0) the model tree features Node sets, Element sets and Surfaces containers also in the Results tab. As I understand, they are needed for the display of contact elements. Do they have additional uses at the moment ? The problem is that the Create option for each of these containers doesn’t work, there’s no effect when it’s pressed. By the way, set and surface creation at the results level could be a quite useful feature if set-based visualization and result export is implemented.
