Mortar contact hard
Mortar Contact hard:
“Hard pressure-overclosure behavior is internally reduced to linear pressure-
overclosure behavior with the default constants. In case of mortar contact true
hard behavior can be simulated by omiting the *SURFACE BEHAVIOR card
within the *SURFACE INTERACTION card.”
If I’m not wrong this is not possible without custom cards in Prepomax right now. *SURFACE BEHAVIOR and *SURFACE INTERACTION are always created together.
It should be sufficient to allow the creation of Surface interactions without Surface behavior.
In Abaqus, you can create empty Surface interaction / Contact property:
This results in:
*Surface Interaction, name=IntProp-1
1.,
