Modeling a Cable and Pulley
Is it possible to model a cable going over a pully 90° with two forces applied to the ends. the element needs to to have tension + bending stiffness and can have frictional contact with the pully similar to Cable280 in ANSYS.
Check this thread: Rigid Body settings in case of contact shell-solid
There are no dedicated element types for that, but you could use regular shell elements in contact with the pulley or even a layer of solid elements to avoid convergence issues.
