Does anybody know what is the default option when you don’t select any amplitudes in Modal Dynamics Setup?
It’s a basic mass-spring system with a spring connected to the ground. And also applied a force on top of the mass.
Amplitude inputs and responses are below.
In the first one, amplitude option is selected to a certain amplitude defined. You can also see the amplitude-time plot on the right. And also response is on the left.
In the second one, no amplitude is selected.
