Hi, I recently tried out version 1.4.0, and noticed 2 things with regards to meshing:
By default, when first opening meshing parameters, mesh settings are in “basic” mode, and you can choose a max and min element size. I then change to “advanced” mode, where I can choose both “absolute” and “relative”. If I choose relative, I now have a max/min size factor. If I change mesh settings back to “basic” (without touching the “relative” setting), now I get the basic options, but with a max/min element factor, not with max/min element size. I assume that the dialog should reset to element size, or otherwise a absolute/relative option should be present.
There is a typo in the mesh settings description, it says “Turn on advanced mash settings”
