Mesh Generation Failed when 'Split Compound Mesh = Yes'
whereas ‘Split Compound Mesh = No’ works fine with identical meshing parameters.
  • PrePoMax 1.3.0
  • Example file Pin1_Split_YES.pmx
Pin1_Split_YES.pmx (5.6 MB)
Please provide your sample model and parameters.
Cheers
Please find attached Pin1_Split_YES.pmx
I have tested the model and I can confirm a bug. A compound mesh is created in netgen, then it is imported into PrePoMax where it is converted to a parabolic mesh and after this, a splitting procedure inside PrePoMax divides the mesh. The problem is obviously in the splitting procedure. I will investigate this further.
I have fixed this problem and I am closing this topic. The fix will be included in the next release version.
