Hi Matej,
Not sure where my problem is ?
I’m appling a moment to a set of nodes on the lip of shell.
Prepomax translates the moment as a unique Cload card , direction 6 (Mz) , value 500Nm.
I’m not obtaining what I would expect so I’m considering:
1-My Prepomax Set up is wrong.
2-The moment is not properly distributed.
Each node on the lip has a different weight (I’m using second order shell elements).
Shouldn’t the moments be distributed with the same proportions that are used for example for traction?
If I distribute the moment by hand , the profile looks fine and section print check is fine too. Constant Stress across the curved shell. Same moment input and Output.
If I distribute the moment using the GUI, VM shows some peaks on the corners and Section print is wrong (Too large). Kind of problem seen when one aplies Cload to a set of nodes.
.fctbNone{ color:#000000; } .fctbStyle0Style1{ background-color:#e6ffe6;color:#008000; } .fctbStyle1{ color:#0000ff; } ** Name: Moment-1 *Cload, Amplitude=Tabular-1 Node_Set-MZ1, 6, 500
Distributed by hand.
Unique card.
LE2: Cylindrical shell bending patch test
