Hello, I want to add load to the part shown in the figure, but I cannot add load to the point I want because the part I specified while adding load is not visible. I wonder what could be the solution to this?
You can temporarily hide parts by pressing the Spacebar when they are selected. Then bring them back to visibility using the same key.
I hid it but it didn’t work. The hidden version is the first photo. What I need are the red lines within the party. I can access these red lines when I click on the part.
I don’t know if I explained the problem well
red lines are in the part
If it’s inside a single part then it might be best to partition it in CAD software before importing to PrePoMax so that you have a compound part whose components can be easily hidden to access the interior. You could also create an element set in PrePoMax and convert it to a part but this has to be done carefully and is usually used only temporarily to look inside the model. Another way would be to enable the section view before starting the selection mode.
I edited Autocad. Thank you for your attention. Enjoy your work ![]()
Best Regards
You can also use the Section view to cut the model visually.
