it seems that hydrostatic pressure works fine with solid elements but there is some issue with shells. The results are x times higher than they should be (according to Abaqus and analytical calculations) where x is the thickness assigned to the shell section. I assume that it’s because the calculation of the hydrostatic pressure doesn’t take the shell thickness into account (as was mentioned in the thread about the development of this feature).
Here’s an example (the thickness was 10 and results are approximately 10 times higher than expected):
@Matej Would it be possible to fix this? If not, can you suggest some workarounds? Maybe for now, PrePoMax could just multiply all the results from each shell element by its thickness?
