I would like to simulate a model under forced vibration (if it’s posible) with this software I’ve started to use. I’m interested in using several excitation curve, such as: time & amplitude, frequency & amplitude, frequency & PSD. For random and harmonic cases.
Best regards
Manuel Fermín Fonseca
Thanks in advanced
Dynamic analysis procedures other than natural frequency extraction are not yet supported. However, you could do the initial setup in PrePoMax, export the input file, make the necessary keyword changes manually, submit the analysis using standalone CalculiX and postprocess it in GraphiX for example. The following dynamic analysis steps are supported in CalculiX:
- linear
- transient modal dynamics
- steady state dynamics
- harmonic periodic loading
- non-harmonic periodic loading
- nonlinear
Thank you sir, I’ll check some videos about cálculix standAlone.
Thank you prof. I’m checking it out … i need deep into cálculix.
