Electric Bass vibrations
I all
Can i simulate the vibration of a string on the electric bass? I need to know in which part of the bass there are more vibrations. The string vibrates at 80 Hz.
Thank you very much.
Giovanni
Currently, only one dynamic analysis procedure is supported - natural frequency extraction. If you want to apply a dynamic load and evaluate the response of the structure in the time or frequency domain, you will have to add the necessary keywords manually. Check CalculiX’s documentation for transient modal dynamics and steady-state dynamics procedures. You will likely need the second one - it’s used for analyses with harmonic loads and provides a response in frequency domain.
Okay,
Thank you very much
Giovanni
