I created a small suspension assembly from 3 parts:
A spring, made from TPU
An upper wishbone, made from Nylon 6
And a pin, made from Steel
I apply a concentrated force in upward direction at the end of the upper wishbone through a reference point, which is connected to the wishbone pin-holes through a rigid body constraint, as can be seen in the screenshot.
it seems stress almost uniform around holes an become unrealistic. Probably, all part connected by tie constraint, penalty contact may need in this case. Or the pin actually glued to another part in reality, so a tangential movement or sliding did not occur?
This is commonly caused by too coarse discretization. Hexahedral elements would be better but they can be applied only on relatively simple geometries. For now, I would refine the mesh there significantly. And make sure that the master surface belongs to a stiffer body with a coarser mesh.
mesh interfere or element collide at slave and master curved surface can be the reason of unexpected results in contact analysis. Try setting to advanced and following curve geometry may solved the problem even without refinement i.e default mesh size.
