Hello: I PrePomax1.3.1 to simulate the shaping process of a metal cup-shaped part, but it doesn’t work properly and shows that there is no correct output of results, please help assess why. kudos Attachments are PMX model files.
cup.pmx (3.1 MB)
Looks like its a bug in PrePoMax (PPM). However, you may try the following steps:
- CCX shows several warnings while solving your problem. Please check them and try to remove corresponding mistakes in the model definition if these mistakes exist.
- Your FRD-file can be read easily by CGX. Check the results, maybe it could help you to understand the reason why these results cannot be shown in PPM.
